Salta al contenuto principale
Classic Ripstik Caster Board Torsion Bar Replacement
Cosa ti serve
  1. Classic Ripstik Caster Board Torsion Bar Replacement, Torsion Bar: passo 1, immagine 1 di 3 Classic Ripstik Caster Board Torsion Bar Replacement, Torsion Bar: passo 1, immagine 2 di 3 Classic Ripstik Caster Board Torsion Bar Replacement, Torsion Bar: passo 1, immagine 3 di 3
    • Use a 5 mm Allen Wrench to remove the two bolts attaching the front and back deck platforms to the torsion bar.
    • If your bolts have rusted, we recommend using WD-40 Specialist: Rust Remover Soak to remove rust from the bolts.
  2. Classic Ripstik Caster Board Torsion Bar Replacement: passo 2, immagine 1 di 3 Classic Ripstik Caster Board Torsion Bar Replacement: passo 2, immagine 2 di 3 Classic Ripstik Caster Board Torsion Bar Replacement: passo 2, immagine 3 di 3
    • Pull the torsion bar and torsion ball shell from each deck platform to separate them.
    • Slide the damaged torsion bar out of the torsion bar shell.
  3. Classic Ripstik Caster Board Torsion Bar Replacement: passo 3, immagine 1 di 2 Classic Ripstik Caster Board Torsion Bar Replacement: passo 3, immagine 2 di 2
    • Clean the torsion bar shell and inner deck platforms of dirt and rust with soap and damp towel.
    • We recommend wearing gloves as you might be dealing with rust.
    • WD-40 Specialist: Rust Remover Soak may be utilized for excessive rust.
  4. Classic Ripstik Caster Board Torsion Bar Replacement: passo 4, immagine 1 di 2 Classic Ripstik Caster Board Torsion Bar Replacement: passo 4, immagine 2 di 2
    • Apply white lithium grease to the inside of the deck platforms and torsion bar shell.
    • Avoid contact with eyes and skin when utilizing white lithium grease.
    • If gloves are unavailable, then you can substitute with a paper towel or popsicle stick to spread grease.
  5. Classic Ripstik Caster Board Torsion Bar Replacement: passo 5, immagine 1 di 3 Classic Ripstik Caster Board Torsion Bar Replacement: passo 5, immagine 2 di 3 Classic Ripstik Caster Board Torsion Bar Replacement: passo 5, immagine 3 di 3
    • Insert the new torsion bar into the torsion bar shell.
    • Align the threaded holes into the original position with the bolt holes.
    • Remember to face the flat side of the thread hole upwards toward the ceiling.
  6. Classic Ripstik Caster Board Torsion Bar Replacement: passo 6, immagine 1 di 2 Classic Ripstik Caster Board Torsion Bar Replacement: passo 6, immagine 2 di 2
    • Reattach the two 5 mm bolts connecting the torsion bar and deck platforms with the Allen wrench.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 11
Tutti i Tempi: 348
