Introduzione
This guide shows how to remove and replace the metal fan cover for a Clarke Floor Sander 07014A.
The blower fan will probably be stuck to the motor axle. In order to pry the fan out, you will need two prying tools—either pry bars or hammers with long claws.
Cosa ti serve
Twist and pull the dust bag collar to disconnect it from the elbow pipe.
Remove the dust bag.
Peel the rubber sleeve down from the elbow pipe to reveal the pipe socket.
Use snap ring pliers to remove the retaining ring on the top of the fan axle.
Use a 3/16" hex key to remove the three 16 mm long bolts along the side of the fan cover.
When you are installing the fan cover, note that the cover is not perfectly round. There is a slightly squared edge, which should sit close to the sander's handle.
Your replacement part will most likely have screw covers on the fan cover bolts. Be sure to remove them before installing the fan cover.
Altre 3 persone hanno completato questa guida.
