Introduzione
This guide shows how to remove and replace the bottom blower plate for a Clarke Floor Sander 07014A. The plate seals the bottom edge of the fan into the blower housing.
The blower fan will probably be stuck to the motor axle. In order to pry the fan out, you will need two prying tools—either pry bars or hammers with long claws.
Cosa ti serve
Twist and pull the dust bag collar to disconnect it from the elbow pipe.
Remove the dust bag.
Peel the rubber sleeve down from the elbow pipe to reveal the pipe socket.
Use snap ring pliers to remove the retaining ring on the top of the fan axle.
Altre 6 persone hanno completato questa guida.
