Introduzione
Taking your clarinet to the music store to get your cork replace can be expensive. Following this guide by removing and replacing the cork yourself can save you a lot of money.
Cosa ti serve
Once your clarinet is reassembled, leave the joint together for at least a few hours to let the cork compress and adhere properly. Play the fully assembled clarinet or blow some air through the joint to check for any leaks. When you are ready to put it away, disassemble it carefully. Enjoy your new cork!
Altre 7 persone hanno completato questa guida.
3 Commenti
Where do you buy the corks from? Could you post a link to them?
Wat if the cork strips don't have adhesive.wat do I use
