Introduzione
When you own a watch for an extended amount of time there is going to be wear on the strap. Instead of buying a new watch you can simply replace the strap.
Cosa ti serve
Flip your watch to the back.
Insert the small end with the bar between the fork. Press outwards; when you feel the pressure, pull up slowly.
Replace the other strap by following the same instructions.
1Commento della guida
After the automatic watch fell to the ground, the back glass was broken and it stopped working
