Salta al contenuto principale
Cisco Meraki MC74-HW Sensor Cover Replacement
Cosa ti serve
  1. Cisco Meraki MC74-HW Sensor Cover Replacement, Back Housing and Device Stand: passo 1, immagine 1 di 3 Cisco Meraki MC74-HW Sensor Cover Replacement, Back Housing and Device Stand: passo 1, immagine 2 di 3 Cisco Meraki MC74-HW Sensor Cover Replacement, Back Housing and Device Stand: passo 1, immagine 3 di 3
    • Extend the stand as far away as possible from the device.
    • Remove all four 3 mm Hex 2 screws from the stand.
    • A bit with a flexible extension may be needed to remove these screws.
  2. Cisco Meraki MC74-HW Sensor Cover Replacement: passo 2, immagine 1 di 2 Cisco Meraki MC74-HW Sensor Cover Replacement: passo 2, immagine 2 di 2
    • Lift the stand off the device.
  3. Cisco Meraki MC74-HW Sensor Cover Replacement: passo 3, immagine 1 di 3 Cisco Meraki MC74-HW Sensor Cover Replacement: passo 3, immagine 2 di 3 Cisco Meraki MC74-HW Sensor Cover Replacement: passo 3, immagine 3 di 3
    • Insert a plastic spudger between the back housing cover and the sensor cover piece.
    • Work your way slowly around the edges of the device until all the clips have been unclipped.
    • Do not insert any tool recklessly into the device or you might damage wires and connections.
  4. Cisco Meraki MC74-HW Sensor Cover Replacement: passo 4, immagine 1 di 2 Cisco Meraki MC74-HW Sensor Cover Replacement: passo 4, immagine 2 di 2
    • Separate the back housing cover from the device completely.
  5. Cisco Meraki MC74-HW Sensor Cover Replacement, Phone Sensor: passo 5, immagine 1 di 2 Cisco Meraki MC74-HW Sensor Cover Replacement, Phone Sensor: passo 5, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    • Disconnect the ribbon from the phone sensor board using a pair of reverse tweezers.
    • Electronic ribbons are very fragile, so pull slowly to disconnect them.
  6. Cisco Meraki MC74-HW Sensor Cover Replacement: passo 6, immagine 1 di 3 Cisco Meraki MC74-HW Sensor Cover Replacement: passo 6, immagine 2 di 3 Cisco Meraki MC74-HW Sensor Cover Replacement: passo 6, immagine 3 di 3
    • Remove the two 1.2 mm screws holding the phone sensor using a Phillips #0 screwdriver.
    • Carefully lift the phone sensor to remove it from the device.
  7. Cisco Meraki MC74-HW Sensor Cover Replacement, Sensor Cover: passo 7, immagine 1 di 3 Cisco Meraki MC74-HW Sensor Cover Replacement, Sensor Cover: passo 7, immagine 2 di 3 Cisco Meraki MC74-HW Sensor Cover Replacement, Sensor Cover: passo 7, immagine 3 di 3
    • Remove the two 1.2 mm screws using a Phillips #0 screwdriver.
    • Remove the sensor cover.
Conclusione
UMass Dartmouth, Team 1-5, Simcock Fall 2021 Membro di UMass Dartmouth, Team 1-5, Simcock Fall 2021
UMASSD-SIMCOCK-F21S1G5
4 Membri
8 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 7
Tutti i Tempi: 214
