Salta al contenuto principale
Circuit Board
Cosa ti serve
  1. Circuit Board, Battery: passo 1, immagine 1 di 2 Circuit Board, Battery: passo 1, immagine 2 di 2
    • Locate the horizontal grip located on the back cover of the phone.
    • Slide the back cover down and off of the phone.
  2. Circuit Board: passo 2, immagine 1 di 2 Circuit Board: passo 2, immagine 2 di 2
    • Insert a plastic opening tool into the battery release point located above the battery.
    • Pull outwards in order to release the battery.
  3. Circuit Board, Circuit Board Housing: passo 3, immagine 1 di 3 Circuit Board, Circuit Board Housing: passo 3, immagine 2 di 3 Circuit Board, Circuit Board Housing: passo 3, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    • Locate the 5 screws holding the body of the phone together.
    • The top screw will have a plastic cover, remove it using tweezers.
    • Using a Philips head screwdriver, twist counterclockwise to remove the screws.
    • Take special care with the screw located at the top of the phone. It is smaller and more likely to be damaged or improperly attached.
  4. Circuit Board: passo 4, immagine 1 di 2 Circuit Board: passo 4, immagine 2 di 2
    • Lift the back cover starting at the bottom of the phone.
  5. Circuit Board: passo 5, immagine 1 di 2 Circuit Board: passo 5, immagine 2 di 2
    • Remove the back cover completely from the phone.
  6. Circuit Board, Circuit Board: passo 6, immagine 1 di 1
    • Locate the clamp at bottom right side of the Circuit Board.
    • Pull the circuit board from the phone being cautious to pull out underneath the clamp.
  7. Circuit Board: passo 7, immagine 1 di 2 Circuit Board: passo 7, immagine 2 di 2
    • Locate the ribbon connecting the circuit board to the phone display.
    • Using the spudger, disconnect the ribbon connecting the phone's display and the circuit board.
    • Remove the circuit board
Conclusione
Clemson, Team 14-7, Benson Fall 2013 Membro di Clemson, Team 14-7, Benson Fall 2013
CLEM-BENSON-F13S14G7
3 Membri
16 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 9
Tutti i Tempi: 639
