Salta al contenuto principale
Circuit Board Housing Removal
Cosa ti serve
  1. Circuit Board Housing Removal, Battery: passo 1, immagine 1 di 2 Circuit Board Housing Removal, Battery: passo 1, immagine 2 di 2
    • Locate the horizontal grip located on the back cover of the phone.
    • Slide the back cover down and off of the phone.
  2. Circuit Board Housing Removal: passo 2, immagine 1 di 2 Circuit Board Housing Removal: passo 2, immagine 2 di 2
    • Insert a plastic opening tool into the battery release point located above the battery.
    • Pull outwards in order to release the battery.
  3. Circuit Board Housing Removal, Circuit Board Housing: passo 3, immagine 1 di 3 Circuit Board Housing Removal, Circuit Board Housing: passo 3, immagine 2 di 3 Circuit Board Housing Removal, Circuit Board Housing: passo 3, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Locate the 5 screws holding the body of the phone together.
    • The top screw will have a plastic cover, remove it using tweezers.
    • Using a Philips head screwdriver, twist counterclockwise to remove the screws.
    • Take special care with the screw located at the top of the phone. It is smaller and more likely to be damaged or improperly attached.
  4. Circuit Board Housing Removal: passo 4, immagine 1 di 2 Circuit Board Housing Removal: passo 4, immagine 2 di 2
    • Lift the back cover starting at the bottom of the phone.
  5. Circuit Board Housing Removal: passo 5, immagine 1 di 2 Circuit Board Housing Removal: passo 5, immagine 2 di 2
    • Remove the back cover completely from the phone.
Conclusione
Clemson, Team 14-7, Benson Fall 2013 Membro di Clemson, Team 14-7, Benson Fall 2013
CLEM-BENSON-F13S14G7
3 Membri
16 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 7
Tutti i Tempi: 622
