Introduzione
This is a replacement guide for the Cirago M9030 Cover. The following steps will guide you in the dismantling and rebuilding of the cover as well as a replacement.
Cosa ti serve
Use a Phillips #00 screwdriver to unscrew the four 1.1mm long screws on each corner located at the top of the cover.
In order to reassemble your device, follow these instructions in reverse order.
