Salta al contenuto principale
Cirago M9030 Cover Replacement
Cosa ti serve
  1. Cirago M9030 Cover Replacement, Cover: passo 1, immagine 1 di 1
    • Use a Phillips #00 screwdriver to unscrew the four 1.1mm long screws on each corner located at the top of the cover.
  2. Cirago M9030 Cover Replacement: passo 2, immagine 1 di 1
    • Similar to the last step, flip the cover over and use a Phillips #00 screwdriver to unscrew the four 1.1mm long screws on each corner located at the bottom of the cover.
    • Remove the warranty sticker across the bottom.
  3. Cirago M9030 Cover Replacement: passo 3, immagine 1 di 2 Cirago M9030 Cover Replacement: passo 3, immagine 2 di 2
    • Gently take the cover apart using your hands separating the top and bottom.
    • The outer shell is expected to easily come apart.
Conclusione
In order to reassemble your device, follow these instructions in reverse order.
Ryan Sutardji
Membro da: 06/29/12
171 Reputazione
7 Guide realizzate
Cal Poly, Team 1-4, Regan SU 2012 Membro di Cal Poly, Team 1-4, Regan SU 2012
CPSU-REGAN-SU12S1G4
4 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 899
