Salta al contenuto principale
Cirago M9030 Battery Replacement
Cosa ti serve
  1. Cirago M9030 Battery Replacement, Cover: passo 1, immagine 1 di 1
    • Use a Phillips #00 screwdriver to unscrew the four 1.1mm long screws on each corner located at the top of the cover.
  2. Cirago M9030 Battery Replacement: passo 2, immagine 1 di 1
    • Similar to the last step, flip the cover over and use a Phillips #00 screwdriver to unscrew the four 1.1mm long screws on each corner located at the bottom of the cover.
    • Remove the warranty sticker across the bottom.
  3. Cirago M9030 Battery Replacement: passo 3, immagine 1 di 2 Cirago M9030 Battery Replacement: passo 3, immagine 2 di 2
    • Gently take the cover apart using your hands separating the top and bottom.
    • The outer shell is expected to easily come apart.
  4. Cirago M9030 Battery Replacement, Hard Drive: passo 4, immagine 1 di 1
    • Make sure that the screen of the device is facing down.
  5. Cirago M9030 Battery Replacement: passo 5, immagine 1 di 3 Cirago M9030 Battery Replacement: passo 5, immagine 2 di 3 Cirago M9030 Battery Replacement: passo 5, immagine 3 di 3
    • Using the plastic opening tool, wedge the tool underneath the bottom left edge of the hard drive.
    • Raise the bottom edge of the hard drive 15 degrees up from the device.
  6. Cirago M9030 Battery Replacement: passo 6, immagine 1 di 3 Cirago M9030 Battery Replacement: passo 6, immagine 2 di 3 Cirago M9030 Battery Replacement: passo 6, immagine 3 di 3
    • Place fingers on the IDE connectors gently picking up and sliding the hard drive out from the IDE module.
  7. Cirago M9030 Battery Replacement, IDE Connector: passo 7, immagine 1 di 2 Cirago M9030 Battery Replacement, IDE Connector: passo 7, immagine 2 di 2
    • Using the Phillips #00 screwdriver, unscrew the two 1.5mm long screws holding the IDE connector to the motherboard located at the top.
  8. Cirago M9030 Battery Replacement: passo 8, immagine 1 di 1
    • Using the Phillips #00 screwdriver, unscrew the three 1.5mm long screws on the metal bracket.
  9. Cirago M9030 Battery Replacement: passo 9, immagine 1 di 2 Cirago M9030 Battery Replacement: passo 9, immagine 2 di 2
    • Using the plastic opening tool, completely lift the metal bracket off of the motherboard.
    • Using the plastic opening tool, completely lift the rubber insulator off of the motherboard.
  10. Cirago M9030 Battery Replacement: passo 10, immagine 1 di 1
    • Using the plastic opening tool, completely lift the ribbon off of the motherboard.
  11. Cirago M9030 Battery Replacement: passo 11, immagine 1 di 2 Cirago M9030 Battery Replacement: passo 11, immagine 2 di 2
    • Completely remove the IDE connector from the device.
    • The audio jack is attached to the IDE connector. Pull at a 45 degree angle from the audio jack.
  12. Cirago M9030 Battery Replacement, Motherboard: passo 12, immagine 1 di 2 Cirago M9030 Battery Replacement, Motherboard: passo 12, immagine 2 di 2
    • Using the plastic opening tool, wedge the tool underneath the top edge of the motherboard.
    • Completely remove the motherboard.
    • The motherboard should slide out easily.
  13. Cirago M9030 Battery Replacement, Button Module: passo 13, immagine 1 di 1
    • Set aside the front cover.
    • Flip over the motherboard.
    • Using the Philips #00 screwdriver, remove the three 4mm long screws holding down the button module.
  14. Cirago M9030 Battery Replacement: passo 14, immagine 1 di 3 Cirago M9030 Battery Replacement: passo 14, immagine 2 di 3 Cirago M9030 Battery Replacement: passo 14, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Using the tweezers, lift up the button module to a 180 degree angle.
    • Leave the button module attached by the ribbon.
    • Flip over the motherboard with the button module still attached.
  15. Cirago M9030 Battery Replacement: passo 15, immagine 1 di 3 Cirago M9030 Battery Replacement: passo 15, immagine 2 di 3 Cirago M9030 Battery Replacement: passo 15, immagine 3 di 3
    • Fold the button module over the motherboard.
    • Using the tweezers, remove the ribbon pin.
    • The ribbon pin should snap completely off of the motherboard.
  16. Cirago M9030 Battery Replacement: passo 16, immagine 1 di 2 Cirago M9030 Battery Replacement: passo 16, immagine 2 di 2
    • The ribbon should easily detach from the motherboard.
  17. Cirago M9030 Battery Replacement, Battery: passo 17, immagine 1 di 2 Cirago M9030 Battery Replacement, Battery: passo 17, immagine 2 di 2
    • Flip over the motherboard so the screen faces up.
    • Carefully slide the battery off of the motherboard.
    • Leave the battery cable connected to the motherboard.
  18. Cirago M9030 Battery Replacement: passo 18, immagine 1 di 3 Cirago M9030 Battery Replacement: passo 18, immagine 2 di 3 Cirago M9030 Battery Replacement: passo 18, immagine 3 di 3
    • Place two fingers on the battery connectors and gently pull the power cable connector completely out from the motherboard.
    • Do not pull directly on the wire as it may damage the connector.
Conclusione
Ryan Sutardji
Membro da: 06/29/12
171 Reputazione
7 Guide realizzate
Cal Poly, Team 1-4, Regan SU 2012 Membro di Cal Poly, Team 1-4, Regan SU 2012
CPSU-REGAN-SU12S1G4
4 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 1,209
