Salta al contenuto principale
Cineyo BT-03 Device Battery Replacement
Cosa ti serve
  1. Cineyo BT-03 Device Battery Replacement, Cineyo BT-03 Device Disassembly: passo 1, immagine 1 di 3 Cineyo BT-03 Device Battery Replacement, Cineyo BT-03 Device Disassembly: passo 1, immagine 2 di 3 Cineyo BT-03 Device Battery Replacement, Cineyo BT-03 Device Disassembly: passo 1, immagine 3 di 3
    • Remove the top (button side) rubber cover using your hands.
  2. Cineyo BT-03 Device Battery Replacement: passo 2, immagine 1 di 2 Cineyo BT-03 Device Battery Replacement: passo 2, immagine 2 di 2
    • Flip over the device and remove the bottom rubber cover using your hands.
  3. Cineyo BT-03 Device Battery Replacement: passo 3, immagine 1 di 3 Cineyo BT-03 Device Battery Replacement: passo 3, immagine 2 di 3 Cineyo BT-03 Device Battery Replacement: passo 3, immagine 3 di 3
    • Using your hands, pull off the plastic side cover (on the side with the audio jack) using the indented tab. The indented tab has been highlighted in the picture.
  4. Cineyo BT-03 Device Battery Replacement: passo 4, immagine 1 di 3 Cineyo BT-03 Device Battery Replacement: passo 4, immagine 2 di 3 Cineyo BT-03 Device Battery Replacement: passo 4, immagine 3 di 3
    • Detach the plastic speaker cover on both the front and back sides. Then slide the cover off of the device.
    • The cover should remain as one solid piece.
  5. Cineyo BT-03 Device Battery Replacement: passo 5, immagine 1 di 1
    • Remove the five 1 cm screws on the back side (opposite of the speakers) of the device using a Phillips #1 screwdriver.
  6. Cineyo BT-03 Device Battery Replacement: passo 6, immagine 1 di 1
    • Gently pull apart the two sections of the device.
  7. Cineyo BT-03 Device Battery Replacement, Battery: passo 7, immagine 1 di 2 Cineyo BT-03 Device Battery Replacement, Battery: passo 7, immagine 2 di 2
    • Pull the wires connecting the blue battery out of the circuit board.
  8. Cineyo BT-03 Device Battery Replacement: passo 8, immagine 1 di 2 Cineyo BT-03 Device Battery Replacement: passo 8, immagine 2 di 2
    • Using your fingers, pull the blue battery out of the casing.
    • There might be slight hesitation due to the adhesive attaching the battery to the casing, so a slight bit of force might be necessary.
Conclusione
Cole Crawford
Membro da: 02/13/17
85 Reputazione
1 Guida realizzata
Baylor, Team 8-3, Whitney Spring 2017 Membro di Baylor, Team 8-3, Whitney Spring 2017
BU-WHITNEY-S17S8G3
5 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 215
