Salta al contenuto principale
Chumby One LCD Screen Replacement
Cosa ti serve
  1. Chumby One LCD Screen Replacement, Chassis: passo 1, immagine 1 di 1
    • Remove 4 self-adhesive plastic dots covering the screw holes.
  2. Chumby One LCD Screen Replacement: passo 2, immagine 1 di 1
    • Remove the four 2mm screws with a Phillips screwdriver.
  3. Chumby One LCD Screen Replacement: passo 3, immagine 1 di 1
    • Remove the back and bottom cover.
  4. Chumby One LCD Screen Replacement: passo 4, immagine 1 di 1
    • Disconnect the battery connector from the motherboard with a plastic opening tool.
  5. Chumby One LCD Screen Replacement: passo 5, immagine 1 di 1
    • Disconnect the microphone connector from the motherboard with a plastic opening tool.
  6. Chumby One LCD Screen Replacement: passo 6, immagine 1 di 1
    • Remove the display ribbon cable from its socket with a plastic opening tool.
  7. Chumby One LCD Screen Replacement: passo 7, immagine 1 di 1
    • Remove the volume knob from the side of the Chumby One with a plastic opening tool.
  8. Chumby One LCD Screen Replacement: passo 8, immagine 1 di 1
    • Remove the four 6mm screws using a PH000 bit on the inner chassis.
  9. Chumby One LCD Screen Replacement: passo 9, immagine 1 di 1
    • Remove the inner components from the outer shell.
  10. Chumby One LCD Screen Replacement, LCD Screen: passo 10, immagine 1 di 1
    • Remove the four 5.5mm screws with a Phillips PH000 screwdriver bit.
  11. Chumby One LCD Screen Replacement: passo 11, immagine 1 di 1
    • Remove the metal shield from the front case using a plastic opening tool.
  12. Chumby One LCD Screen Replacement: passo 12, immagine 1 di 1
    • Remove the LCD screen from the outer case using a plastic opening tool.
Conclusione
Jordan Houchins
Membro da: 03/27/17
401 Reputazione
4 Guide realizzate
IUPUI, Team S3-G3, Baechle Spring 2017 Membro di IUPUI, Team S3-G3, Baechle Spring 2017
IUPUI-BAECHLE-S17S3G3
4 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 9
Tutti i Tempi: 243
