Salta al contenuto principale
Chromo Inc. T2 Internal Speaker Replacement
Cosa ti serve
  1. Chromo Inc. T2 Internal Speaker Replacement, Removing the Casing: passo 1, immagine 1 di 3 Chromo Inc. T2 Internal Speaker Replacement, Removing the Casing: passo 1, immagine 2 di 3 Chromo Inc. T2 Internal Speaker Replacement, Removing the Casing: passo 1, immagine 3 di 3
    • Using your Plastic Opening Tool, place it in between the screen and the case. Slowly move it around the casing while prying in a downward motion to undo the hinges holding the two together and separate the two parts.
  2. Chromo Inc. T2 Internal Speaker Replacement, Turn it around: passo 2, immagine 1 di 1
    • After separating the case and screen, turn your screen face down so you can see the internal parts!
  3. Chromo Inc. T2 Internal Speaker Replacement, Removing the Tape: passo 3, immagine 1 di 3 Chromo Inc. T2 Internal Speaker Replacement, Removing the Tape: passo 3, immagine 2 di 3 Chromo Inc. T2 Internal Speaker Replacement, Removing the Tape: passo 3, immagine 3 di 3
    • Remove two strips of tape: One holding down the wires and the other holding down the internal speaker.
  4. Chromo Inc. T2 Internal Speaker Replacement, Desoldering the Wires and Removing the Speaker: passo 4, immagine 1 di 3 Chromo Inc. T2 Internal Speaker Replacement, Desoldering the Wires and Removing the Speaker: passo 4, immagine 2 di 3 Chromo Inc. T2 Internal Speaker Replacement, Desoldering the Wires and Removing the Speaker: passo 4, immagine 3 di 3
    • Using a Soldering Iron, desolder both speaker wires. Once both wires are desoldered, your Internal Speaker is now ready for replacement!
    • Soldering Iron gets very hot, take care to not touch anywhere on the soldering iron except for the handle!
Conclusione
USF Tampa, Team 15-1, Watkins Winter 2015 Membro di USF Tampa, Team 15-1, Watkins Winter 2015
USFT-WATKINS-W15S15G1
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 9
Tutti i Tempi: 217
