Salta al contenuto principale
Chromo Inc. T2 Battery Replacement
Cosa ti serve
  1. Chromo Inc. T2 Battery Replacement, Removing the Casing: passo 1, immagine 1 di 3 Chromo Inc. T2 Battery Replacement, Removing the Casing: passo 1, immagine 2 di 3 Chromo Inc. T2 Battery Replacement, Removing the Casing: passo 1, immagine 3 di 3
    • Place your Plastic Opening Tool between the screen and the case. Slowly move it around the casing while prying in a downward motion to undo the hinges holding the two together and separate the two parts.
  2. Chromo Inc. T2 Battery Replacement, Turn it around: passo 2, immagine 1 di 1
    • After separating the case and screen, turn your screen face down so you can see the internal parts!
  3. Chromo Inc. T2 Battery Replacement, Freeing the Battery: passo 3, immagine 1 di 3 Chromo Inc. T2 Battery Replacement, Freeing the Battery: passo 3, immagine 2 di 3 Chromo Inc. T2 Battery Replacement, Freeing the Battery: passo 3, immagine 3 di 3
    • Using the Spudger, going between the battery and screen, pry the battery off from the tablet.
    • Note: This will require a little extra force due to the tape holding down the battery!
  4. Chromo Inc. T2 Battery Replacement, Desoldering the Battery Wires: passo 4, immagine 1 di 1
    • Using a Soldering Iron, desolder both Battery wires.
    • Soldering Iron gets very hot, take care to not touch anywhere on the soldering iron except for the handle!
  5. Chromo Inc. T2 Battery Replacement, Finished!: passo 5, immagine 1 di 1
    • Your battery is now ready to be replaced!
Conclusione
Altre 2 persone hanno completato questa guida.
USF Tampa, Team 15-1, Watkins Winter 2015 Membro di USF Tampa, Team 15-1, Watkins Winter 2015
USFT-WATKINS-W15S15G1
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 14
Tutti i Tempi: 1,572
