Salta al contenuto principale
Chromecast Case Replacement
Cosa ti serve
  1. Chromecast Case Replacement, Case: passo 1, immagine 1 di 1
    • Place the Google Chromecast face down (with text not showing) on a flat surface.
    • Insert a flat tool just above the micro-USB port to detach the top part of the case from the bottom.
  2. Chromecast Case Replacement: passo 2, immagine 1 di 1
    • Continue prying the top of the case from the bottom toward the HDMI port until the top casing is completely removed.
  3. Chromecast Case Replacement: passo 3, immagine 1 di 1
    • Remove the circuit board, lifting from the HDMI port.
    • The power button may become dislodged.
  4. Chromecast Case Replacement: passo 4, immagine 1 di 1
    • Pry the plastic clamp from the heatsink.
    • Do not pry too hard to avoid breaking the clamp.
  5. Chromecast Case Replacement: passo 5, immagine 1 di 2 Chromecast Case Replacement: passo 5, immagine 2 di 2
    • Insert a plastic opening tool under the heatsink, and pry the heatsink up and out of the case.
    • The adhesive's strength may vary, and force should be applied gently until it becomes dislodged to avoid breaking the device.
Conclusione
Altre 5 persone hanno completato questa guida.
IUPUI, Team S5-G6, Baechle Spring 2018 Membro di IUPUI, Team S5-G6, Baechle Spring 2018
IUPUI-BAECHLE-S18S5G6
3 Membri
6 Guide realizzate
Un commento
que hacer si el pin de centro de carga se despredio como pegarlo o soldarlo?
edgar arreola - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 22
Tutti i Tempi: 1,531
