Salta al contenuto principale
Chromebook x360 14-da0011dx Fan Replacement
Cosa ti serve
  1. Chromebook x360 14-da0011dx Fan Replacement, Lower Case: passo 1, immagine 1 di 1
    • Flip the device over with the hinge facing away from you.
    • On the back of the device, remove the two rubber strips on the top and the bottom of the device using a spudger.
  2. Chromebook x360 14-da0011dx Fan Replacement: passo 2, immagine 1 di 2 Chromebook x360 14-da0011dx Fan Replacement: passo 2, immagine 2 di 2
    • Remove the seven 8.0 mm screws located under the two rubber pads and the screws along the back of the device using a Phillips #1 screwdriver.
  3. Chromebook x360 14-da0011dx Fan Replacement: passo 3, immagine 1 di 3 Chromebook x360 14-da0011dx Fan Replacement: passo 3, immagine 2 di 3 Chromebook x360 14-da0011dx Fan Replacement: passo 3, immagine 3 di 3
    • Use a spudger to gently pry the edges of the back cover off the device. Slowly work all the way around the device until the panel comes loose.
  4. Chromebook x360 14-da0011dx Fan Replacement, Battery: passo 4, immagine 1 di 2 Chromebook x360 14-da0011dx Fan Replacement, Battery: passo 4, immagine 2 di 2
    • Remove the cable attached to the battery.
  5. Chromebook x360 14-da0011dx Fan Replacement: passo 5, immagine 1 di 2 Chromebook x360 14-da0011dx Fan Replacement: passo 5, immagine 2 di 2
    • Remove the five 3.0 mm screws holding the battery in place using the Phillips #1 screwdriver.
  6. Chromebook x360 14-da0011dx Fan Replacement: passo 6, immagine 1 di 1
    • Lift the battery out of the chassis.
  7. Chromebook x360 14-da0011dx Fan Replacement, Fan: passo 7, immagine 1 di 1
    • Remove the two 3.0 mm Phillips #1 screws holding the fan in place.
  8. Chromebook x360 14-da0011dx Fan Replacement: passo 8, immagine 1 di 2 Chromebook x360 14-da0011dx Fan Replacement: passo 8, immagine 2 di 2
    • Disconnect the fan cable from the motherboard.
    • Carefully remove the fan from the computer.
    • Be careful when removing the fan, as it sits under one of the CPU heat pipes and tucks under the ribbon cable that runs to the I/O board.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 10
Tutti i Tempi: 175
