Salta al contenuto principale
Chromebook 14-x015wm Keyboard Replacement
Cosa ti serve
  1. Chromebook 14-x015wm Keyboard Replacement, Keyboard: passo 1, immagine 1 di 2 Chromebook 14-x015wm Keyboard Replacement, Keyboard: passo 1, immagine 2 di 2
    • Remove the small rubber circles over all four corners on the bottom of the chromebook.
    • Remove the three small additional rubber covers along edge of computer with hinge.
    • Unscrew all the screws on the bottom of the laptop using a Phillips #00 screwdriver.
    • Make sure to keep track of the screws for reassembly.
  2. Chromebook 14-x015wm Keyboard Replacement: passo 2, immagine 1 di 1
    • Flip the laptop back over to the front and open it so that the keyboard is visible.
    • Use the iFixit opening tool to pry off the keyboard by placing the tool in-between the keyboard and the case. Move the tool around all sides until the keyboard separates.
    • The keyboard will likely be difficult to remove.
    • Be careful to avoid pulling on the ribbons that connect the keyboard to the internal components in order to prevent damage.
  3. Chromebook 14-x015wm Keyboard Replacement: passo 3, immagine 1 di 1
    • Carefully unclip the ribbons under the keyboard to disconnect the keyboard.
    • Replace the keyboard and connect the ribbons to the new keyboard.
    • Press the computer case shut and replace the screws and rubber pads.
Linea Traguardo
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 8
Tutti i Tempi: 451
