Introduzione
This guide applies to 2015-2017 model cars which have the "MagneRide" active suspension. The rear shock absorbers on these vehicles are prone to early failure and must be removed and replaced. You'll know your rear shocks need to be replaced if they're leaving a puddle of oily fluid on the ground just inside of the rear tires.
Cosa ti serve
With the vehicle parked on a flat surface, engage the parking brake
Make sure the park light illuminates on the dashboard.
As an extra safety measure, block the wheel on the opposite side from where you're lifting the car
If removing the wheel, break the nuts before lifting the car with a breaker bar and 22mm or 7/8" socket.
If your car was equipped with a spare tire kit, you can use that wrench too.
When lifting the car, DO NOT use a jack on the pinch welds. Instead, use the plate on the frame rails as shown.
When lifting with a jack and supporting with a jackstand:
Place the jack here
Place the jack stand here
I like to place towels or something else soft between the jack / stands and the car to protect the paint
Lift the car with the jack until you have the wheel a few inches off the ground. Then insert the jack stand and lower the car onto it.
If removing the rear wheel, fully loosen the lugs and set the wheel aside
There's a small arm linking the lower control arm to a vehicle height sensor.
Separate the link from the lower control arm
It takes a little force to pop the linkage off, a flat head screwdriver or trim removal tool can make the process easier.
Using a 15mm wrench and socket, remove the stabilizer bar link
Pressure from the suspension may keep the middle plastic "grommet" section in place, you can wiggle it out or wait until the lower control arm is fully freed to remove it.
When reassembling, torque this to around 30ft-lbs.
A single 18mm nut and bolt secures the strut assembly to the lower control arm
Remove the nut with a ratchet while holding the other side with wrench
When re-assembling, this should be torqued to about 60ft-lbs, then tightened an additional quarter turn.
When re-assembling, the jack will be necessary to align the control arm and strut to re-install the nut and bolt.
An 18mm nut and bolt secures the lower control arm to the rear knuckle and must be removed.
Like the strut-to-LCA bolt, this may require "finessing" the lower control arm with a jack to remove.
When reassembling, torque this to around 35ft-lbs. You will need to do some prying with a pry-bar or large screwdriver in concert with a jack to get this realigned so you can re-insert the bolt.
After this step, the lower control arm should move freely.
The strut is electrically connected to the car via a 2-pin connector near where the strut mounts to the body.
There's a small tab on the connector which you must depress to get it disconnected.
Four 15mm bolts attach the strut to the body of the vehicle.
Remove the bolts, the strut should come free from the body.
When re-assembling, these bolts should be torqued to around 45ft-lbs.
You should be able to slide the strut out with the lower control arm depressed.
The order that I've found which makes re-assembly the easiest is:
Install the strut-to-LCA nut/bolt, but keep them loose.
Install the strut-to-body bolts, but keep them loose
Install the LCA-to-knuckle nut/bolt, with the help of a jack and prybar. This step is probably the most difficult.
Get all nuts/bolts tightened snugly.
Raise the LCA with the jack to "simulate" the car sitting on the ground, compressing the suspension. Then, torque everything to specifications.
Move the strut assembly to a workbench, organization is important for this process because there are many parts in the strut assembly. It must be re-assembled in the correct order!
The 2-pin connector at the top of the strut assembly slides into a grove, slide it out!
There's an angled shell which wraps around the base of the connector, press on plastic tabs to remove it from the connector and set it aside.
You may have noticed that the electrical connector is larger than the hole at the top of the strut, it can't be slid through!
The pins must be removed from the connector housing, this process requires some finesse.
Make a "depinning tool" with a standard sized paperclip by bending it as shown
Straighten most of the paperclip, but bend the end slightly
This will be used to release the pins from the connector housing
To release the pins from the connector, press the paperclip into the purple holes adjacent to each pin
While pressing the paperclip into the hole, gently pull the wire from the back of the connector while wiggling the paperclip
Pay attention to how the pins sit in the housing, the pin must align with the connector housing when reassembled
With both pins removed from the connector, you can slide them through the top part of the strut.
The orientation of the colored wires in the connector is different on the driver and passenger side struts.
The first image shows the driver side pinout with one of the wires partially removed
The second image shows the passenger side pinout with one of the wires removed
Look closely at the connector shell orientation in both pictures, as well as the orientation of the black / orange wire.
A zip tie holds the cable to a plastic ring at the top of the shock, cut it
Remove the plastic ring / aligner and put it somewhere safe
Using MacPherson strut compressors, compress the spring slightly.
You only need to compress the strut by around half an inch, just enough to allow further disassembly.
Hold the center shaft of the strut with a 3/8" wrench while removing the nut at the top of the strut with an 18mm wrench.
Slide the nut over the cable and remove it
When reassembling, torque the nut to around 35ft-lbs.
Remove the top washer, mounting plate/bushing, lower washer, and dust cap, keeping track of the order you removed them.
The removable components are shown left-to-right in the order they go onto the strut.
Remove the small black washer and the yellow spacer.
The top of the spacer is labeled
You should now be able to slide the shock absorber out of the spring.
This shock absorber shows all the symptoms of failure, it's coated in oily ferrofluid and grime.
The new one is nice and clean!
Most reassembly steps are just the reverse of disassembly, but here are some notes / advice:
To reassemble, insert the new shock absorber into the coil spring and re-install the stackup of parts. Tighten the top strut nut, and install a new zip tie to keep the cable correctly oriented. Route the electrical harness through the mounting plate then install the pins into the electrical connector, matching the colors to how they were originally installed. They should click into place and not be removable by hand.
To reinstall the strut into the car, loosely fasten it to the body first, then use a floor jack to aid in positioning the lower arm until you can get the bolt reinstalled.
