Salta al contenuto principale
Chef's Choice M115 Power Switch Replacement
Cosa ti serve
  1. Chef's Choice M115 Power Switch Replacement, Case: passo 1, immagine 1 di 2 Chef's Choice M115 Power Switch Replacement, Case: passo 1, immagine 2 di 2
    • Remove the two rubber feet on the motor side of the device.
    • Remove the five Phillips screws from the bottom of the case.
    • These screws are recessed deep in the device, so a long, thin screwdriver is required.
  2. Chef's Choice M115 Power Switch Replacement: passo 2, immagine 1 di 1
    • Remove the two hex-cap screws on the bottom using a pair of pliers.
  3. Chef's Choice M115 Power Switch Replacement: passo 3, immagine 1 di 1
    • Carefully flip the device right-side-up while grasping the top and bottom pieces.
    • The white cover should lift off with no resistance. If it does not, ensure all screws were removed in previous step.
  4. Chef's Choice M115 Power Switch Replacement: passo 4, immagine 1 di 1
    • Remove the sharpener guard by gently pulling up on it.
    • If the sharpener guard does not come off easily, ensure all screws were removed in step 1.
  5. Chef's Choice M115 Power Switch Replacement, Power Switch: passo 5, immagine 1 di 1
    • Carefully lift the entire motor assembly out of the case.
  6. Chef's Choice M115 Power Switch Replacement: passo 6, immagine 1 di 2 Chef's Choice M115 Power Switch Replacement: passo 6, immagine 2 di 2
    • Using a screw driver, unclip the edges of the switch by pushing them inwards and nudging the switch out of the plastic casing. You will hear a click when the edges unhook from the casing.
  7. Chef's Choice M115 Power Switch Replacement: passo 7, immagine 1 di 2 Chef's Choice M115 Power Switch Replacement: passo 7, immagine 2 di 2
    • Remove the spade connectors from the switch by pulling only on the connector, not the wire.
    • This may require a fair bit of force. Use caution to not damage the device, yourself, or your surroundings.
Conclusione
Altre 2 persone hanno completato questa guida.
IUPUI, Team 3-3, Harley Fall 2015 Membro di IUPUI, Team 3-3, Harley Fall 2015
IUPUI-HARLEY-F15S3G3
5 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 5
Tutti i Tempi: 323
