Salta al contenuto principale
Changing the Bath NF SIRYO CHROME thermostatic cartridge
  1. Changing the Bath NF SIRYO CHROME thermostatic cartridge, Access to the thermostatic cartridge: passo 1, immagine 1 di 3 Changing the Bath NF SIRYO CHROME thermostatic cartridge, Access to the thermostatic cartridge: passo 1, immagine 2 di 3 Changing the Bath NF SIRYO CHROME thermostatic cartridge, Access to the thermostatic cartridge: passo 1, immagine 3 di 3
    • WARNING: Before any intervention, make sure that the inverter is in the "OFF" position and close the water supply to the meter.
    • Using a flat screwdriver, unclip the cover to access the handle fixing screw.
    • Unscrew the fixing screw counterclockwise.
  2. Changing the Bath NF SIRYO CHROME thermostatic cartridge, Dismantling the thermostatic handle: passo 2, immagine 1 di 3 Changing the Bath NF SIRYO CHROME thermostatic cartridge, Dismantling the thermostatic handle: passo 2, immagine 2 di 3 Changing the Bath NF SIRYO CHROME thermostatic cartridge, Dismantling the thermostatic handle: passo 2, immagine 3 di 3
    • Before disassembling, check that the mark on the mixer tap is aligned with the "38°" position, then remove the handle.
    • ATTENTION: before extracting the stop ring (38°), check that the two notches are aligned with the mark on the mixer
    • Extract the thrust ring
  3. Changing the Bath NF SIRYO CHROME thermostatic cartridge, Removing the thermostatic cartridge: passo 3, immagine 1 di 3 Changing the Bath NF SIRYO CHROME thermostatic cartridge, Removing the thermostatic cartridge: passo 3, immagine 2 di 3 Changing the Bath NF SIRYO CHROME thermostatic cartridge, Removing the thermostatic cartridge: passo 3, immagine 3 di 3
    • Unscrew the thermostatic cartridge anti-clockwise using a 21 wrench.
    • Extract the cartridge by hand.
  4. Changing the Bath NF SIRYO CHROME thermostatic cartridge, Reassembly: passo 4, immagine 1 di 3 Changing the Bath NF SIRYO CHROME thermostatic cartridge, Reassembly: passo 4, immagine 2 di 3 Changing the Bath NF SIRYO CHROME thermostatic cartridge, Reassembly: passo 4, immagine 3 di 3
    • Insert the thermostat in the mixer body.
    • Screw in clockwise by hand.
    • Finish the tightening using the spanner 21.
    • ATTENTION: The tightening torque must not exceed 10Nm. We therefore advise you to use a torque wrench so as not to damage the thread of the thermostatic cartridge.
  5. Changing the Bath NF SIRYO CHROME thermostatic cartridge, Replacing and adjusting the stop ring: passo 5, immagine 1 di 3 Changing the Bath NF SIRYO CHROME thermostatic cartridge, Replacing and adjusting the stop ring: passo 5, immagine 2 di 3 Changing the Bath NF SIRYO CHROME thermostatic cartridge, Replacing and adjusting the stop ring: passo 5, immagine 3 di 3
    • Position the two lines marked on the stop ring facing the point of the mixer tap.
    • Turn on the water supply to proceed with the adjustment step.
    • Turn the diverter handle to run the water, then place a thermometer under the flow to check the correct temperature, which should be 38°.
    • If the temperature is not 38°, adjust by turning the wheel clockwise to decrease the temperature (-°C).
    • And counterclockwise to increase the temperature (+°C).
  6. Changing the Bath NF SIRYO CHROME thermostatic cartridge, Replacing the handle: passo 6, immagine 1 di 3 Changing the Bath NF SIRYO CHROME thermostatic cartridge, Replacing the handle: passo 6, immagine 2 di 3 Changing the Bath NF SIRYO CHROME thermostatic cartridge, Replacing the handle: passo 6, immagine 3 di 3
    • Align the reference point on the mixer body with the 38° mark on the handle.
    • Tighten the handle fixing screw using a Phillips screwdriver in a clockwise direction.
    • Replace the cover.
Conclusione
Un ringraziamento speciale a questi traduttori:
fr en
100%
Questi traduttori ci stanno aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
iRobot
Membro da: 09/24/09
1 Reputazione
636 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 35
Tutti i Tempi: 1,797
