Salta al contenuto principale
Cen-Tech Seven Function Digital Multimeter Buzzer Replacement
Cosa ti serve
  1. Cen-Tech Seven Function Digital Multimeter Buzzer Replacement, Adding buzzer: passo 1, immagine 1 di 3 Cen-Tech Seven Function Digital Multimeter Buzzer Replacement, Adding buzzer: passo 1, immagine 2 di 3 Cen-Tech Seven Function Digital Multimeter Buzzer Replacement, Adding buzzer: passo 1, immagine 3 di 3
    • To open you multimeter take off the screws that are circled in the first image
    • The screws are very important make sure to keep them safe and not to loose them
  2. Cen-Tech Seven Function Digital Multimeter Buzzer Replacement: passo 2, immagine 1 di 2 Cen-Tech Seven Function Digital Multimeter Buzzer Replacement: passo 2, immagine 2 di 2
    • The red and black arrows point to the positive or red and negative or black for the power of the 2 volt buzzer
    • Use a multimeter and make sure that there really is voltage coming out of there
Conclusione
Altre 2 persone hanno completato questa guida.
Busy Bee
Membro da: 06/20/21
139 Reputazione
1 Guida realizzata
1Commento della guida
Your red arrow is really obscure its hard to tell what it's pointing to exactly. Btw thanks so much for this I've been using mine for years without a beeper, finally someone figured it out and posted their modification.
lilthumper98 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 18
Tutti i Tempi: 821
