Salta al contenuto principale
Celestron 71328 Nature DX 8x25 Skin Cover Replacement
Cosa ti serve
  1. Celestron 71328 Nature DX 8x25 Skin Cover Replacement, Skin Cover: passo 1, immagine 1 di 2 Celestron 71328 Nature DX 8x25 Skin Cover Replacement, Skin Cover: passo 1, immagine 2 di 2
    • Using a plastic opening tool, nylon spudger or metal spudger, pry into seam of the skin cover at the center of the device. Lightly lift the tool which should cause the skin cover to rise.
  2. Celestron 71328 Nature DX 8x25 Skin Cover Replacement: passo 2, immagine 1 di 2 Celestron 71328 Nature DX 8x25 Skin Cover Replacement: passo 2, immagine 2 di 2
    • Start peeling the skin away from the center. Apply force as there is an adhesive substance that is binding the skin to the device. Continue peeling until skin cover slides off completely.
  3. Celestron 71328 Nature DX 8x25 Skin Cover Replacement: passo 3, immagine 1 di 1
    • Repeat steps 1 and 2 for the other side.
Conclusione
USF Tampa, Team S6-G6, Lacy Spring 2017 Membro di USF Tampa, Team S6-G6, Lacy Spring 2017
USFT-LACY-S17S6G6
4 Membri
10 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 329
