Introduzione
Use this guide to replace the main circuit board of the device. This requires detaching all other components, including those that are soldered to the board.
Strumenti
Parti
Nessuna parte richiesta.
Lay the device on its back, and rotate so the base is facing away from you.
Unplug the cable connecting the display to the power supply using the flat end of the spudger to pry the connector away from the circuit board.
