Salta al contenuto principale
Ceiva LF2003 Internal Plastic Screen Frame Replacement
Cosa ti serve
  1. Ceiva LF2003 Internal Plastic Screen Frame Replacement, Exterior Frame and Matting: passo 1, immagine 1 di 1
    • Lay the device on its back, and rotate so the base is facing away from you.
  2. Ceiva LF2003 Internal Plastic Screen Frame Replacement: passo 2, immagine 1 di 1
    • Grip the frame with your fingers under the edge of the frame, and thumbs pushing down on the front of the device.
  3. Ceiva LF2003 Internal Plastic Screen Frame Replacement: passo 3, immagine 1 di 1
    • Lift up the frame with your fingers and push down the rest of the device with your thumbs.
  4. Ceiva LF2003 Internal Plastic Screen Frame Replacement: passo 4, immagine 1 di 1
    • Remove the frame and matte from the device.
  5. Ceiva LF2003 Internal Plastic Screen Frame Replacement, Internal Plastic Screen Frame: passo 5, immagine 1 di 1
    • Remove the four 7mm Torx T6 screws.
  6. Ceiva LF2003 Internal Plastic Screen Frame Replacement: passo 6, immagine 1 di 2 Ceiva LF2003 Internal Plastic Screen Frame Replacement: passo 6, immagine 2 di 2
    • Using the plastic opening tool or your fingers, lift up the frame from any edge.
    • Remove the frame from the device.
Conclusione
Casey Glasgow
Membro da: 01/26/14
510 Reputazione
5 Guide realizzate
Cal Poly, Team 9-25, Maness Winter 2014 Membro di Cal Poly, Team 9-25, Maness Winter 2014
CPSU-MANESS-W14S9G25
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 9
Tutti i Tempi: 95
