Salta al contenuto principale
Ceiva LF2003 Exterior Frame and Matting Replacement
  1. Ceiva LF2003 Exterior Frame and Matting Replacement, Exterior Frame and Matting: passo 1, immagine 1 di 1
    • Lay the device on its back, and rotate so the base is facing away from you.
  2. Ceiva LF2003 Exterior Frame and Matting Replacement: passo 2, immagine 1 di 1
    • Grip the frame with your fingers under the edge of the frame, and thumbs pushing down on the front of the device.
  3. Ceiva LF2003 Exterior Frame and Matting Replacement: passo 3, immagine 1 di 1
    • Lift up the frame with your fingers and push down the rest of the device with your thumbs.
  4. Ceiva LF2003 Exterior Frame and Matting Replacement: passo 4, immagine 1 di 1
    • Remove the frame and matte from the device.
Conclusione
Casey Glasgow
Membro da: 01/26/14
510 Reputazione
5 Guide realizzate
Cal Poly, Team 9-25, Maness Winter 2014 Membro di Cal Poly, Team 9-25, Maness Winter 2014
CPSU-MANESS-W14S9G25
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 12
Tutti i Tempi: 91
