Salta al contenuto principale
Ceiling Fan Light Fixture Replacement
Cosa ti serve
  1. Ceiling Fan Light  Fixture Replacement, Light Fixture: passo 1, immagine 1 di 3 Ceiling Fan Light  Fixture Replacement, Light Fixture: passo 1, immagine 2 di 3 Ceiling Fan Light  Fixture Replacement, Light Fixture: passo 1, immagine 3 di 3
    • Working with electrical wires could lead to electrocution.
    • Find your circuit breaker panel and turn off the breaker that corresponds to your ceiling lights.
    • Do this by pushing it to the right.
    • Also flip your light switch to off.
  2. Ceiling Fan Light  Fixture Replacement: passo 2, immagine 1 di 2 Ceiling Fan Light  Fixture Replacement: passo 2, immagine 2 di 2
    • Remove the two 1.4 mm Phillips head screws that hold the fixture to the fan itself.
    • Once loose, pull down to expose the two connecting wires.
  3. Ceiling Fan Light  Fixture Replacement: passo 3, immagine 1 di 3 Ceiling Fan Light  Fixture Replacement: passo 3, immagine 2 di 3 Ceiling Fan Light  Fixture Replacement: passo 3, immagine 3 di 3
    • Disconnect these wires by twisting the caps in a counter-clockwise direction.
    • You only need to disconnect the wires coming from the lighting fixture.
    • Once both caps are removed, simply pull the wires apart to remove the fixture.
  4. Ceiling Fan Light  Fixture Replacement: passo 4, immagine 1 di 2 Ceiling Fan Light  Fixture Replacement: passo 4, immagine 2 di 2
    • Loosen the nut holding the ceiling fan piece to the lighting fixture.
    • This step may require a crescent wrench if finger force is not enough.
  5. Ceiling Fan Light  Fixture Replacement: passo 5, immagine 1 di 1
    • Pull upwards to remove the fan piece that holds the light fixture.
    • Your model may require you to twist this piece in a counter-clockwise motion to remove.
  6. Ceiling Fan Light  Fixture Replacement: passo 6, immagine 1 di 1
    • Switch out the old fixture with your new fixture by doing the last two steps in reverse order.
  7. Ceiling Fan Light  Fixture Replacement: passo 7, immagine 1 di 2 Ceiling Fan Light  Fixture Replacement: passo 7, immagine 2 di 2
    • To connect your new fixture, locate the black wire from your light and the colored wire from the fan.
    • Be sure to attached the colored wires to each other, and white wires to each other. (Positive-Positive, Negative-Negative)
    • Twist these together. Do the same with the two white wires.
  8. Ceiling Fan Light  Fixture Replacement: passo 8, immagine 1 di 2 Ceiling Fan Light  Fixture Replacement: passo 8, immagine 2 di 2
    • Your new light fixture should come with replacement caps. Twist these in a clockwise motion over your wire ends to ensure connection.
    • The old caps work just as well for this if you were not given new ones.
  9. Ceiling Fan Light  Fixture Replacement: passo 9, immagine 1 di 1
    • Be sure to neatly tuck in all wires when re-attaching the fixture.
    • Failure to do this will result in not being able to correctly close the gap and put in the screws.
  10. Ceiling Fan Light  Fixture Replacement: passo 10, immagine 1 di 1
    • Flip your breaker back on, turn on your light switch, and enjoy your new lights!
Conclusione
Altre 12 persone hanno completato questa guida.
Cal Poly, Team 14-1, Green Fall 2015 Membro di Cal Poly, Team 14-1, Green Fall 2015
CPSU-GREEN-F15S14G1
4 Membri
4 Guide realizzate
11Commenti sulla guida
Amazingly instructive, informative and concise. Brilliant.
Jeanie Bolin-Moore - Replica
Just what I needed. Thanks.
bob.mohler - Replica
Could someone provide the name of the light fixture used in the demonstration?
THOMAS DUFF - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 35
Ultimi 30 Giorni: 149
Tutti i Tempi: 36,036
