Salta al contenuto principale
Caterpillar B15 SIM Card Replacement
Cosa ti serve
  1. Caterpillar B15 SIM Card Replacement, SIM Card: passo 1, immagine 1 di 1
    • Place the phone screen-side down and place thumb on the yellow and black switch. Slide the switch to the right to unlock the back covering for removal.
  2. Caterpillar B15 SIM Card Replacement: passo 2, immagine 1 di 2 Caterpillar B15 SIM Card Replacement: passo 2, immagine 2 di 2
    • Remove the back covering by gently lifting upwards from the bottom of the back covering. The back will snap off and the battery is exposed.
  3. Caterpillar B15 SIM Card Replacement: passo 3, immagine 1 di 2 Caterpillar B15 SIM Card Replacement: passo 3, immagine 2 di 2
    • Place index finger at the top edge of the battery and gently lift upwards. The battery will slide cleanly out of the phone. The SIM card slot lies under the battery.
  4. Caterpillar B15 SIM Card Replacement: passo 4, immagine 1 di 1
    • The old SIM card is removed and replaced with the new one. The phone can be reassembled by following these steps in reverse order.
Conclusione
Altre 2 persone hanno completato questa guida.
USF Tampa, Team 4-7, Brown Fall 2014 Membro di USF Tampa, Team 4-7, Brown Fall 2014
USFT-BROWN-F14S4G7
4 Membri
10 Guide realizzate
Un commento
Mi celular dice SIM no detectada que puedo hacer
Jerson Vargas - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 53
Tutti i Tempi: 15,060
