Introduzione
Do you have a Casio Edifice watch with a broken or ill-fitting band? Use this guide to fix or resize the watchband and return the watch to its former glory.
Cosa ti serve
Locate the hole for the pin you would like to remove.
Insert the Sim Card Eject tool (a safety pin may work as well) inthe hole. Make sure to insert in the hole on the back side of the arrow.
To add links:
Push both link pins back into the watch. Make sure to insert the link pin on the front side of the arrow.
Lightly tap a hammer until pins are flush against both sides of the watchband.
For micro adjustments, push the Sim Card Eject tool into the adjustable side of the clasp. Carefully move pins to the correct fitting holes.
Do not let the pins slide out past the band AT ALL!!! There is an internal spring pressing against both the pins at either end of the rod. Allowing the pin to slide out past the band will shoot the internal part of the pin and the spring. The spring and pin ends are NOT held captive inside the rod at all.
To disassemble the clasp, follow the last 3 steps in reverse order.
Altre 8 persone hanno completato questa guida.
3 Commenti
These are good tips. Repairing a watch can be tricky especially if moisture creeps in. If you're stuck for help, check out http://TimesTicking.com I have used them many times. Very helpful!
Hi, where can I buy link pins? I have the ones with the spring, but the others - I have not been able to find online.
Here is good chanal for watch repairing https://www.youtube.com/watch?v=n1FQgn95...
