Salta al contenuto principale
Casio WK-220 Black Keys Replacement
Cosa ti serve
  1. Casio WK-220 Black Keys Replacement, White Keys: passo 1, immagine 1 di 2 Casio WK-220 Black Keys Replacement, White Keys: passo 1, immagine 2 di 2
    • Place device face-down
    • Remove 23 16mm screws with Phillips #2 screwdriver
  2. Casio WK-220 Black Keys Replacement: passo 2, immagine 1 di 2 Casio WK-220 Black Keys Replacement: passo 2, immagine 2 di 2
    • Pry up long back panels with plastic opening tool
    • Remove panels
  3. Casio WK-220 Black Keys Replacement: passo 3, immagine 1 di 1
    • Turn device around so keys are face-up
  4. Casio WK-220 Black Keys Replacement: passo 4, immagine 1 di 2 Casio WK-220 Black Keys Replacement: passo 4, immagine 2 di 2
    • Pull back panel away from keyboard and out of the way
  5. Casio WK-220 Black Keys Replacement: passo 5, immagine 1 di 3 Casio WK-220 Black Keys Replacement: passo 5, immagine 2 di 3 Casio WK-220 Black Keys Replacement: passo 5, immagine 3 di 3
    • Remove speaker(s) if necessary to access desired key section(s)
    • Use Phillips #2 screwdriver to remove two 16 mm screws (circled in red)
    • Pop wires out of plastic holders so speaker can be moved out of the way
    • Move speaker out of the way
    • See speaker replacement guide for more detail on these steps
  6. Casio WK-220 Black Keys Replacement: passo 6, immagine 1 di 3 Casio WK-220 Black Keys Replacement: passo 6, immagine 2 di 3 Casio WK-220 Black Keys Replacement: passo 6, immagine 3 di 3
    • Remove 4 18 mm screws (circled in red) from desired key section using Philips #1 screwdriver
    • Gently push white keys away from screws and pull up to remove from keyboard. Repeat this with the black keys
    • Reassemble with new/cleaned keys
  7. Casio WK-220 Black Keys Replacement, Black Keys: passo 7, immagine 1 di 2 Casio WK-220 Black Keys Replacement, Black Keys: passo 7, immagine 2 di 2
    • Remove second white section covering desired black section
    • Remove screws using Phillips #1 screwdriver
    • Push keys away from screws and pull up
  8. Casio WK-220 Black Keys Replacement: passo 8, immagine 1 di 3 Casio WK-220 Black Keys Replacement: passo 8, immagine 2 di 3 Casio WK-220 Black Keys Replacement: passo 8, immagine 3 di 3
    • Use plastic opening tool to pry up black key section
    • Remove black key section
    • Reassemble with new/clean black key section
Conclusione
Alexa
Membro da: 01/24/17
687 Reputazione
6 Guide realizzate
Cal Poly, Team 10-2, Banghart Winter 2017 Membro di Cal Poly, Team 10-2, Banghart Winter 2017
CPSU-BANGHART-W17S10G2
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 3
Tutti i Tempi: 829
