Salta al contenuto principale
Casio SPF-40 2273 Battery Replacement
Cosa ti serve
  1. Casio SPF-40 2273 Battery Replacement, Battery: passo 1, immagine 1 di 3 Casio SPF-40 2273 Battery Replacement, Battery: passo 1, immagine 2 di 3 Casio SPF-40 2273 Battery Replacement, Battery: passo 1, immagine 3 di 3
    • This super strong Casio watch is more docile than waht you might think.
    • We don't need to twist off the front's screws.
    • It doesn't bite, so let's turn it around
  2. Casio SPF-40 2273 Battery Replacement: passo 2, immagine 1 di 3 Casio SPF-40 2273 Battery Replacement: passo 2, immagine 2 di 3 Casio SPF-40 2273 Battery Replacement: passo 2, immagine 3 di 3
    • With the phillips screwdriver take off these four screws
    • Lift up an extremity of the watchstrap and remove the base.
    • You can use a flat screwdriver to help you
    • With the tweezers lift the white plastic cover
    • Be careful to not damage the golden springs!! So take your time
  3. Casio SPF-40 2273 Battery Replacement: passo 3, immagine 1 di 3 Casio SPF-40 2273 Battery Replacement: passo 3, immagine 2 di 3 Casio SPF-40 2273 Battery Replacement: passo 3, immagine 3 di 3
    • With the tip of the tweezers you have to unclip the clips into the red rectangles.
    • Just insert the tweezer's tip in the center of the bracket and pull toward the center of the watch
  4. Casio SPF-40 2273 Battery Replacement: passo 4, immagine 1 di 3 Casio SPF-40 2273 Battery Replacement: passo 4, immagine 2 di 3 Casio SPF-40 2273 Battery Replacement: passo 4, immagine 3 di 3
    • Extract the battery leveraging with the tweezers.
    • Keep attention to the golden springs again!
    • The clip, holding down the central batteries, completely removes
Conclusione
Altre 5 persone hanno completato questa guida.
Acn0w
Membro da: 09/20/18
12.057 Reputazione
1 Guida realizzata
3 Commenti
cannot see the “Golden Springs”. Where are they? Thank you
mike.malapascua - Replica
would be nice to have a description if the battery type, to buy before disassembling.. Thank you
mike
Sorry if I wasn’t imprecise, the “Golden Springs” is located above the first battery on the left. More precisely in second step of the guide I marked it.
Coin shaped Batteries are Sony SR927W:
* 1.55 Volt
* 60 mAh
Acn0w -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 9
Ultimi 7 Giorni: 46
Ultimi 30 Giorni: 140
Tutti i Tempi: 9,289
