Salta al contenuto principale
Casio MTD-120 Battery Replacement
Cosa ti serve
  1. Casio MTD-120 Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Place the watch upside down.
  2. Casio MTD-120 Battery Replacement: passo 2, immagine 1 di 2 Casio MTD-120 Battery Replacement: passo 2, immagine 2 di 2
    • Remove the back cover of the watch with tweezers.
    • This should reveal a plastic cover once the back is removed.
  3. Casio MTD-120 Battery Replacement: passo 3, immagine 1 di 2 Casio MTD-120 Battery Replacement: passo 3, immagine 2 di 2
    • Remove the plastic cover with the tweezers.
    • You should now see the battery compartment.
  4. Casio MTD-120 Battery Replacement: passo 4, immagine 1 di 1
    • Remove the battery with the tweezers.
    • Use your fingers to remove the battery if you find it difficult using the tweezers.
  5. Casio MTD-120 Battery Replacement: passo 5, immagine 1 di 1
    • Insert the new battery by pushing down gently.
    • The battery needed for this watch is an SR920SW.
    • Recycle the old battery.
    • Where To Recycle Batteries
  6. Casio MTD-120 Battery Replacement: passo 6, immagine 1 di 2 Casio MTD-120 Battery Replacement: passo 6, immagine 2 di 2
    • Place the plastic cover back over battery compartment.
    • Align the marked area of the plastic cover with the crown of the watch.
    • The crown is the knob that is used to set the watch.
  7. Casio MTD-120 Battery Replacement: passo 7, immagine 1 di 1
    • Put the cover back and tighten it shut by pressing on it.
Conclusione
Follow the link provided in step 5 to find more information on recycling your old batteries.
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 36
Ultimi 30 Giorni: 147
Tutti i Tempi: 3,551
