Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Store
Parti
  1. This is the calculator in question.
    • This is the calculator in question.
    • Features a black and white dot matrix screen.
  2. Turn the calculator over. Locate the six screws on the rear of the device.
    • Turn the calculator over.
    • Locate the six screws on the rear of the device.
    • These are Philips #00 screws.
    • Keep the screws you remove in a safe place so they don't get lost.
  3. Once the screws are removed, carefully lift the back panel off, lifting the top end first. Place the panel to one side.
    • Once the screws are removed, carefully lift the back panel off, lifting the top end first.
    • Place the panel to one side.
    • You can now see the battery.
  4. Remove the battery
    • Remove the battery
    • Lift it up from the right hand side to avoid damaging the spring.
    • You may find this easier to do by prying it out with the screwdriver.
  5. Now you can insert the new battery Ensure you place it in spring-first.
    • Now you can insert the new battery
    • Ensure you place it in spring-first.
    • Congratulations! You have replaced the battery.
    • When reassembling, take care not to trap the red or black wires in the screws as this would sever them, making the calculator unusable.
    • Once reassembled, the calculator will be turned on. Turn it off to save battery by pressing Shift --> AC.
Conclusione
To reassemble your device, follow these instructions in reverse order, noting the two reassembly instructions in the last step.
Altre 26 persone hanno completato questa guida.
Sam
Membro da: 23/09/2012
950 Reputazione
1 Guida realizzata
For some reason the two top screws made the calculator unstable, but removing them made it stable. Only occurred after removing the battery
Mida Galbraith - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 46
Ultimi 30 Giorni: 248
Tutti i Tempi: 47,254
