Introduzione
Key's stuck or broken? No problem. Replace sets of keys in no time with the help of a screwdriver.
Cosa ti serve
You will begin by removing 4 screws on each side of the piano, circled in red.
You will then remove the four screws that are a little hidden, circled in orange.
Next, remove the two screws in the middle of piano, as well as the three screws on the top of the piano, circled in yellow.
After flipping the keyboard over to the front, carefully remove the the front panel from the back panel of the keyboard using your hands.
You should now see the screws holding the keys in place.
With a JIS-1 bit, unscrew the five screws in the section with the key you want to replace.
