Salta al contenuto principale
Casio G'zOne Commando Verizon MIL-SPEC Motherboard Replacement
Cosa ti serve
  1. Casio G'zOne Commando Verizon MIL-SPEC Motherboard Replacement, Battery: passo 1, immagine 1 di 1
    • Slide the slider on the back of the phone to the free position.
  2. Casio G'zOne Commando Verizon MIL-SPEC Motherboard Replacement: passo 2, immagine 1 di 1
    • Using a plastic opening tool, gently lift open the back panel from bottom of the panel.
  3. Casio G'zOne Commando Verizon MIL-SPEC Motherboard Replacement: passo 3, immagine 1 di 2 Casio G'zOne Commando Verizon MIL-SPEC Motherboard Replacement: passo 3, immagine 2 di 2
    • Pull the white battery tab upwards and remove the battery.
  4. Casio G'zOne Commando Verizon MIL-SPEC Motherboard Replacement, Motherboard: passo 4, immagine 1 di 1
    • Remove the four 6mm Y0 screws from the corners of the device.
  5. Casio G'zOne Commando Verizon MIL-SPEC Motherboard Replacement: passo 5, immagine 1 di 1
    • Remove the four 5mm Y0 screws from the back of the device.
  6. Casio G'zOne Commando Verizon MIL-SPEC Motherboard Replacement: passo 6, immagine 1 di 1
    • Using a spudger, pry away the motherboard from its compartment, by inserting the spudger in the compartment and lifting upwards until fully out.
  7. Casio G'zOne Commando Verizon MIL-SPEC Motherboard Replacement: passo 7, immagine 1 di 1
    • Lastly, using your hands, separate the motherboard from its compartment.
Conclusione
Zack Almeida
Membro da: 10/24/18
392 Reputazione
4 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 5
Tutti i Tempi: 249
