Salta al contenuto principale
  1. Using the Phillips #00 screwdriver remove the front and back 5.0 mm screws as shown in the picture. There are four screws in the back and two screws in the front.
    • Using the Phillips #00 screwdriver remove the front and back 5.0 mm screws as shown in the picture.
    • There are four screws in the back and two screws in the front.
  2. Gently remove the side cover from the phone  by lifting up on the corners as shown in the picture. Press down on the screen to help remove the plastic side cover from the phone. Make sure to push gently because the frame is fragile.
    • Gently remove the side cover from the phone by lifting up on the corners as shown in the picture.
    • Press down on the screen to help remove the plastic side cover from the phone.
    • Make sure to push gently because the frame is fragile.
  3. Pull the side front cover off the face of the phone.
    • Pull the side front cover off the face of the phone.
  4. Remove the eight 2.5mm Phillips #00 screws in the holes of the casing. Remove the eight 2.5mm Phillips #00 screws in the holes of the casing. Remove the eight 2.5mm Phillips #00 screws in the holes of the casing.
    • Remove the eight 2.5mm Phillips #00 screws in the holes of the casing.
  5. Gently pull off the motherboard cover.
    • Gently pull off the motherboard cover.
  6. Using the Phillips #00, remove all 2.5 mm screws attached to the motherboard.
    • Using the Phillips #00, remove all 2.5 mm screws attached to the motherboard.
    • Do not touch the integrated circuits in the motherboard.
  7. Gently remove the motherboard with the spudger. Gently remove the motherboard with the spudger.
    • Gently remove the motherboard with the spudger.
  8. Following step 4 in the prerequisite guide, remove the volume pads located on the side of the phone with a gentle pull. Following step 4 in the prerequisite guide, remove the volume pads located on the side of the phone with a gentle pull.
    • Following step 4 in the prerequisite guide, remove the volume pads located on the side of the phone with a gentle pull.
  9. Following step 6, remove the adapter connecting the volume buttons to the motherboard.
    • Following step 6, remove the adapter connecting the volume buttons to the motherboard.
Conclusione
Brett Boehm
Membro da: 25/09/2014
281 Reputazione
2 Guide realizzate
USF Tampa, Team 1-5, Brown Fall 2014 Membro di USF Tampa, Team 1-5, Brown Fall 2014
USFT-BROWN-F14S1G5
3 Membri
3 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 118
