Salta al contenuto principale
Casio G’zOne Commando 4G LTE Sim Card Replacement
Cosa ti serve
  1. Casio G’zOne Commando 4G LTE Sim Card Replacement, Battery: passo 1, immagine 1 di 1
    • In order to get at the battery, you will have to pull the locking tab to the “Free” position. Once you do that you will have to pry the battery cover off (using a plastic opening tool or similar prying tool). Because the phone is designed to be waterproof, it is advised that you do NOT use your fingernails.
  2. Casio G’zOne Commando 4G LTE Sim Card Replacement: passo 2, immagine 1 di 2 Casio G’zOne Commando 4G LTE Sim Card Replacement: passo 2, immagine 2 di 2
    • Once the battery cover is off, there is another lock holding the battery in place. However, with this lock all you have to do is slide the lock to “Free”, and pull the battery out by lifting it from the bottom side (the side with the orange lock).
  3. Casio G’zOne Commando 4G LTE Sim Card Replacement, Sim Card: passo 3, immagine 1 di 1
    • After removing the battery you will find a port that is labeled SIM directly beneath where the battery was sitting.
  4. Casio G’zOne Commando 4G LTE Sim Card Replacement: passo 4, immagine 1 di 1
    • In order to remove the SD card lift the tab that is located directly to the left of the card. Then slide the SD card out of its port and remove it from the cell phone.
Conclusione
Altre 3 persone hanno completato questa guida.
Keith Hickey
Membro da: 10/29/15
428 Reputazione
3 Guide realizzate
UMass Dartmouth, Team 1-9, Miles Fall 2015 Membro di UMass Dartmouth, Team 1-9, Miles Fall 2015
UMASSD-MILES-F15S1G9
3 Membri
10 Guide realizzate
2 Commenti
My Casio C811 will not go to a browser, keeps saying no network connection. I am in an area that I have had connection with no problems before. The phone did some sort of reset on it own and now wont access any browser, google, Facebook ect. I have check the network setting and they appear OK. Any suggestions
bernmntsa - Replica
How do I unlock my Casio Commando C811 to use with non-verizon SIM…!?
Alrn Arun - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 32
Tutti i Tempi: 4,555
