Salta al contenuto principale
Casio G’zOne Commando 4G LTE Motherboard Replacement
Cosa ti serve
  1. Casio G’zOne Commando 4G LTE Motherboard Replacement, Motherboard: passo 1, immagine 1 di 1
    • First, you are going to want to take out the two front screws from the device.
    • The screws are 4mm in length and require a Y0 bit to remove
  2. Casio G’zOne Commando 4G LTE Motherboard Replacement: passo 2, immagine 1 di 1
    • Using the same screw head, remove the back four screws from the device.
  3. Casio G’zOne Commando 4G LTE Motherboard Replacement: passo 3, immagine 1 di 2 Casio G’zOne Commando 4G LTE Motherboard Replacement: passo 3, immagine 2 di 2
    • You should have taken out six screws (two from the front, four from the back). Once you do this, you will have to separate the front and back casing of the phone using a spudger or pry tool.
  4. Casio G’zOne Commando 4G LTE Motherboard Replacement: passo 4, immagine 1 di 1
    • Now, you have six more screws to unscrew (three on each side). They are all the same size but smaller than the first six we took off.
    • These screws are 4mm in length and require a PH00 tip to remove.
  5. Casio G’zOne Commando 4G LTE Motherboard Replacement: passo 5, immagine 1 di 1
    • Once you unscrew all six screws, you can easily separate the plastic shell with your hands.
  6. Casio G’zOne Commando 4G LTE Motherboard Replacement: passo 6, immagine 1 di 2 Casio G’zOne Commando 4G LTE Motherboard Replacement: passo 6, immagine 2 di 2
    • Again, there are six more (and even smaller) screws to take out. Additionally, you have to disconnect a small wire plugged into the motherboard.
    • These screws are 2mm in length and require a PH000 tip to remove.
  7. Casio G’zOne Commando 4G LTE Motherboard Replacement: passo 7, immagine 1 di 2 Casio G’zOne Commando 4G LTE Motherboard Replacement: passo 7, immagine 2 di 2
    • After removing the screws carefully separate the motherboard from the shell with the spudger.
Conclusione
Altre 3 persone hanno completato questa guida.
UMass Dartmouth, Team 1-9, Miles Fall 2015 Membro di UMass Dartmouth, Team 1-9, Miles Fall 2015
UMASSD-MILES-F15S1G9
3 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 8
Tutti i Tempi: 581
