Salta al contenuto principale
Casio G’zOne Commando 4G LTE Battery Replacement
Cosa ti serve
  1. Casio G’zOne Commando 4G LTE Battery Replacement, Battery: passo 1, immagine 1 di 1
    • In order to get at the battery, you will have to pull the locking tab to the “Free” position. Once you do that you will have to pry the battery cover off (using a plastic opening tool or similar prying tool). Because the phone is designed to be waterproof, it is advised that you do NOT use your fingernails.
  2. Casio G’zOne Commando 4G LTE Battery Replacement: passo 2, immagine 1 di 2 Casio G’zOne Commando 4G LTE Battery Replacement: passo 2, immagine 2 di 2
    • Once the battery cover is off, there is another lock holding the battery in place. However, with this lock all you have to do is slide the lock to “Free”, and pull the battery out by lifting it from the bottom side (the side with the orange lock).
Conclusione
To install a new battery in your device, follow these instructions in reverse order.
UMass Dartmouth, Team 1-9, Miles Fall 2015 Membro di UMass Dartmouth, Team 1-9, Miles Fall 2015
UMASSD-MILES-F15S1G9
3 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 13
Tutti i Tempi: 740
