Salta al contenuto principale
Casio G’zOne Commando 4G LTE Volume Buttons Replacement
Cosa ti serve
  1. Casio G’zOne Commando 4G LTE Volume Buttons Replacement, Remove front and back screws: passo 1, immagine 1 di 2 Casio G’zOne Commando 4G LTE Volume Buttons Replacement, Remove front and back screws: passo 1, immagine 2 di 2
    • Using the Phillips #00 screwdriver remove the front and back 5.0 mm screws as shown in the picture.
    • There are four screws in the back and two screws in the front.
  2. Casio G’zOne Commando 4G LTE Volume Buttons Replacement, Remove side-Back cover: passo 2, immagine 1 di 3 Casio G’zOne Commando 4G LTE Volume Buttons Replacement, Remove side-Back cover: passo 2, immagine 2 di 3 Casio G’zOne Commando 4G LTE Volume Buttons Replacement, Remove side-Back cover: passo 2, immagine 3 di 3
    • Gently remove the side cover from the phone by lifting up on the corners as shown in the picture.
    • Press down on the screen to help remove the plastic side cover from the phone.
    • Make sure to push gently because the frame is fragile.
  3. Casio G’zOne Commando 4G LTE Volume Buttons Replacement, Remove Side-Front cover: passo 3, immagine 1 di 1
    • Pull the side front cover off the face of the phone.
  4. Casio G’zOne Commando 4G LTE Volume Buttons Replacement: passo 4, immagine 1 di 3 Casio G’zOne Commando 4G LTE Volume Buttons Replacement: passo 4, immagine 2 di 3 Casio G’zOne Commando 4G LTE Volume Buttons Replacement: passo 4, immagine 3 di 3
    • Remove the eight 2.5mm Phillips #00 screws in the holes of the casing.
  5. Casio G’zOne Commando 4G LTE Volume Buttons Replacement: passo 5, immagine 1 di 1
    • Gently pull off the motherboard cover.
  6. Casio G’zOne Commando 4G LTE Volume Buttons Replacement: passo 6, immagine 1 di 1
    • Using the Phillips #00, remove all 2.5 mm screws attached to the motherboard.
    • Do not touch the integrated circuits in the motherboard.
  7. Casio G’zOne Commando 4G LTE Volume Buttons Replacement, Motherboard: passo 7, immagine 1 di 2 Casio G’zOne Commando 4G LTE Volume Buttons Replacement, Motherboard: passo 7, immagine 2 di 2
    • Gently remove the motherboard with the spudger.
  8. Casio G’zOne Commando 4G LTE Volume Buttons Replacement, Removing external volume pads: passo 8, immagine 1 di 2 Casio G’zOne Commando 4G LTE Volume Buttons Replacement, Removing external volume pads: passo 8, immagine 2 di 2
    • Following step 4 in the prerequisite guide, remove the volume pads located on the side of the phone with a gentle pull.
  9. Casio G’zOne Commando 4G LTE Volume Buttons Replacement, Removing internal volume buttons: passo 9, immagine 1 di 1
    • Following step 6, remove the adapter connecting the volume buttons to the motherboard.
Conclusione
Brett Boehm
Membro da: 09/25/14
281 Reputazione
2 Guide realizzate
USF Tampa, Team 1-5, Brown Fall 2014 Membro di USF Tampa, Team 1-5, Brown Fall 2014
USFT-BROWN-F14S1G5
3 Membri
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 132
