Salta al contenuto principale
Casio FX-115ES PLUS Battery Replacement
Cosa ti serve
  1. Casio FX-115ES PLUS Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Turn off the calculator by pressing the [shift] button.
    • Press the [AC] [OFF] button to turn off the calculator by pressing the [shift] button.
    Chiedi a FixBot
    Aggiungi Commento
  2. Casio FX-115ES PLUS Battery Replacement: passo 2, immagine 1 di 3 Casio FX-115ES PLUS Battery Replacement: passo 2, immagine 2 di 3 Casio FX-115ES PLUS Battery Replacement: passo 2, immagine 3 di 3
    • Turn the calculator the other way around so that the small panel in the top right corner of the back of the calculator faces forward.
    • Use a Phillips #0 screwdriver to remove the screw in the upper right corner.
    • Don't force the screwdriver on the screw, as it can strip the screw
    Chiedi a FixBot
    Aggiungi Commento
  3. Casio FX-115ES PLUS Battery Replacement: passo 3, immagine 1 di 1
    • Remove the battery cover.
    Chiedi a FixBot
    Aggiungi Commento
  4. Casio FX-115ES PLUS Battery Replacement: passo 4, immagine 1 di 1
    • Insert the spudger in the available slot in the middle of the right side.
    • Use the spudger to take the battery out carefully.
    • Be careful when removing the battery to avoid any damage.
    Chiedi a FixBot
    Aggiungi Commento
  5. Casio FX-115ES PLUS Battery Replacement: passo 5, immagine 1 di 1
    • Place the new 357 oxide button battery into the calculator.
    • Make sure that the + sign is at the bottom.
    Chiedi a FixBot
    Aggiungi Commento
  6. Casio FX-115ES PLUS Battery Replacement: passo 6, immagine 1 di 3 Casio FX-115ES PLUS Battery Replacement: passo 6, immagine 2 di 3 Casio FX-115ES PLUS Battery Replacement: passo 6, immagine 3 di 3
    • Reattach the battery cover.
    • Insert the screw back in place along with the cover using a Phillips #0 screwdriver.
    • Make sure to turn the screwdriver clockwise to lock the screw in tight, preventing the battery from falling out.
    Chiedi a FixBot
    Aggiungi Commento
  7. Casio FX-115ES PLUS Battery Replacement: passo 7, immagine 1 di 1
    • Reset the calculator by pressing [ON].
    • Press the [Shift] button.
    • Press the [9] [CLR] button to clear the data.
    • Press the [3] [ALL] button option.
    • Press the [=] [yes] button to accept.
    • Press the [AC] key to reset completely.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
You have successfully replaced a Casio FX-115ES PLUS battery
Rodrigo Lopez
Membro da: 01/23/23
145 Reputazione
Una guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 3
Ultimi 7 giorni: 20
Ultimi 30 giorni: 95
Tutti i Tempi: 4,281
