Introduzione
This guide shows you how to remove the zoom lens from the camera.
Remove the four screws on the side with the speaker
  • Remove the four screws on the side with the speaker
Aggiungi Commento
Remove the four screws from the bottom of the camera.
  • Remove the four screws from the bottom of the camera.
  • Note: Bottom screws are longer than the top ones, so label accordingly for easy reassembly
Aggiungi Commento
  • Remove the four screws on the side opposite of the speaker.
Aggiungi Commento
  • Once all screws have been removed, gently pry open bottom casing.
  • With tweezers, carefully remove ribbon from LCD screen.
  • Set bottom casing aside.
Aggiungi Commento
  • Remove ribbon from the rear casing.
  • Set aside rear casing.
Aggiungi Commento
  • Use tweezers or prongs to pry the LCD screen off from the opening.
  • Note: the bottom of the LCD screen is attached to the frame by a few pieces of black tape.
Aggiungi Commento
  • Lift up the LCD screen, slowly move it to the other side.
Aggiungi Commento
  • Pry off the LCD casing which is taped on to the frame.
Aggiungi Commento
  • Flip open the connector holding the ribbon.
  • Pull out the LCD screen with the ribbon from the camera.
Aggiungi Commento
  • Pull apart the front casing.
Aggiungi Commento
  • Remove two screws on the side where the battery is located.
  • Remove the lanyard loop after the screws come off.
  • Slowly pull the side casing so it becomes dislocated from the top of the camera frame.
Aggiungi Commento
  • On the front of the camera near the flash flip the connector holding the ribbon.
  • Remove the ribbon from the connector.
Aggiungi Commento
  • Carefully remove the L shaped frame from the camera.
  • At the bottom of the camera the L shaped frame is being held in by two plastic bumps and a metal tab. Pop the frame off the bumps and tabs.
  • Note: There is a yellow and orange wire soldered onto the camera. Be careful not to pull them off.
  • The blue box is the speaker box.
Aggiungi Commento
  • On the logic board next to the lens is a connector with a ribbon.
  • Flip the connector and remove the ribbon
Aggiungi Commento
  • Remove the frame on the back side of the camera where the LCD screen was.
  • Remove the two screws connecting the frame with the camera
  • Slowly pry off the frame from the camera
  • After removing the frame a plastic piece with two yellow button connections should fall off.
  • Note: This plastic piece is soldered to two wires a yellow and orange one.
Aggiungi Commento
  • On the back of the camera where the LCD screen was, remove 3 screws located behind the lens.
Aggiungi Commento
  • Remove the large orange ribbon previously held in by screws from the camera.
Aggiungi Commento
  • On the backside of the camera where the indicator lamp is located remove the two screws.
Aggiungi Commento
  • On the side of the indicator lamp remove a screw.
  • On the front side of the indicator lamp remove the a screw.
  • This should remove the indicator lamp from the lens.
Aggiungi Commento
  • The lens is now detached from the camera except for the ribbon soldered onto the logic board.
Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
Ray
Membro da: 25/01/2011
219 Reputazione
1 Guida realizzata
Cal Poly, Team 4-38, Regan Winter 2011 Membro di Cal Poly, Team 4-38, Regan Winter 2011
CPSU-REGAN-W11S4G38
4 Membri
7 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 7,990
