Introduzione
This guide will show you how to properly remove and replace the Casio Exilim EX-Z80 camera lens in the case that the lens has been broken or scratched. It will require the use of the Casio Exilim EX-Z80 Back and Front Cover Replacement Guide.
Cosa ti serve
Remove the four 3 mm black screws from the bottom of the camera using a Phillips #000 screwdriver.
Open the battery compartment with your thumb or index finger.
Remove the single 2 mm silver screw that is now exposed using a Phillips #000 screwdriver.
Gently flip the wide button cable up from the display cable.
Lift the brown retention flap on the display cable ZIF connector with tweezers or an ESD-safe tool.
Carefully pull the display cable from its connector.
Lift the retaining flaps on the two ZIF connectors that secure the the lens ribbon cables to the motherboard.
Carefully pull the two ribbon cables from their sockets on the motherboard.
