Salta al contenuto principale
Casio Exilim EX-Z70 Memory Card Replacement
  1. Casio Exilim EX-Z70 Memory Card Replacement, Memory Card: passo 1, immagine 1 di 3 Casio Exilim EX-Z70 Memory Card Replacement, Memory Card: passo 1, immagine 2 di 3 Casio Exilim EX-Z70 Memory Card Replacement, Memory Card: passo 1, immagine 3 di 3
    • Orient the camera with the lens facing to the right and the bottom of the camera toward you.
    • Grasping the camera tightly, press downward firmly on the piece with the label and slide it towards the LCD screen (to the left).
    • The flap will then swing upward.
  2. Casio Exilim EX-Z70 Memory Card Replacement: passo 2, immagine 1 di 2 Casio Exilim EX-Z70 Memory Card Replacement: passo 2, immagine 2 di 2
    • Push down on the memory card (located behind the battery) and then release pressure completely.
    • The memory card will automatically rise part way out of its compartment.
    • Grasp the memory card on each side and simply slide it out of its compartment to remove it.
  3. Casio Exilim EX-Z70 Memory Card Replacement: passo 3, immagine 1 di 3 Casio Exilim EX-Z70 Memory Card Replacement: passo 3, immagine 2 di 3 Casio Exilim EX-Z70 Memory Card Replacement: passo 3, immagine 3 di 3
    • If your memory card is locked, there is a metal slider on the left side that can be moved up to unlock the memory card.
Conclusione
Altre 2 persone hanno completato questa guida.
Paul Fallon
Membro da: 04/10/12
147 Reputazione
6 Guide realizzate
Cal Poly, Team 17-28, Amido Spring 2012 Membro di Cal Poly, Team 17-28, Amido Spring 2012
CPSU-AMIDO-S12S17G28
4 Membri
14 Guide realizzate
3Commenti sulla guida
My Casio camera works great until I insert the memory card. When it doesn't have the memory card, it turns on, the lenses come out and everything but as soon as I insert the memory card, the lenses will come out have way, and then the camera shuts off like that. The only way to get the lenses to get inside and the camera to turn on, is to remove the memory card. HELP ME PLEASE!
Miriam - Replica
I have a similar issue. My camera won’t recognize the SD card! It’ll turn on & take pic’s in the Memory area, but them it’s FULL after a few. Isn’t there something that can be done?
I see NO ONE HAS ANSWERED THE LAST PERSONS QUESTION….????????????
Lynn Lehr - Replica
Hi, I’m like an almost a decade late!! But you need to format the card. You can use a laptop or some cameras (not any Casio ones tha I’m aware of) will do it too. I’m not sure what formatting does? But it works for me everytime :))
Kaylia -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 41
Tutti i Tempi: 4,222
