Salta al contenuto principale
Casio ClassWiz fx-880 battery replacement
  1. Casio ClassWiz  fx-880 battery replacement, MAKE SURE TO SHUT DOWN YOUR CALCULATOR FIRST OF ALL: passo 1, immagine 1 di 2 Casio ClassWiz  fx-880 battery replacement, MAKE SURE TO SHUT DOWN YOUR CALCULATOR FIRST OF ALL: passo 1, immagine 2 di 2
    • SERIOUSLY, I saw a guy at my school do this without shutting his calculator down and apparently he could NOT start up his calculator anymore. PLUS, it's just so much smarter to just shut it down first!
    Chiedi a FixBot
    Aggiungi Commento
  2. Casio ClassWiz  fx-880 battery replacement, Flip it over and unscrew it!: passo 2, immagine 1 di 3 Casio ClassWiz  fx-880 battery replacement, Flip it over and unscrew it!: passo 2, immagine 2 di 3 Casio ClassWiz  fx-880 battery replacement, Flip it over and unscrew it!: passo 2, immagine 3 di 3
    • So after you shut it down, you like flip it to it's back with your HAND
    • So, after you flip it over, take your most trusty phillip screwdriver you have and with all your might, do ahead and unscrew that baby
    Chiedi a FixBot
    Aggiungi Commento
  3. Casio ClassWiz  fx-880 battery replacement, Take off that back!: passo 3, immagine 1 di 1
    • Unscrewed it? Now, pop off that back and look at the beauty hiding inside it, it's just so magnificent!
    Chiedi a FixBot
    Aggiungi Commento
  4. Casio ClassWiz  fx-880 battery replacement, Pop off that battery: passo 4, immagine 1 di 2 Casio ClassWiz  fx-880 battery replacement, Pop off that battery: passo 4, immagine 2 di 2
    • Now, get your HANDS, and then, just pop that AAA battery, just like popping off a heart of a human
    Chiedi a FixBot
    Aggiungi Commento
  5. Casio ClassWiz  fx-880 battery replacement, Pop that new battery in: passo 5, immagine 1 di 2 Casio ClassWiz  fx-880 battery replacement, Pop that new battery in: passo 5, immagine 2 di 2
    • Now take your new AAA battery and then just pop that thing into the battery slot
    Chiedi a FixBot
    Aggiungi Commento
  6. Casio ClassWiz  fx-880 battery replacement, Pop that back back on: passo 6, immagine 1 di 3 Casio ClassWiz  fx-880 battery replacement, Pop that back back on: passo 6, immagine 2 di 3 Casio ClassWiz  fx-880 battery replacement, Pop that back back on: passo 6, immagine 3 di 3
    • You now, just pop the back of the calculator back on
    • You screw the back back in
    Chiedi a FixBot
    Aggiungi Commento
  7. Casio ClassWiz  fx-880 battery replacement, test it!: passo 7, immagine 1 di 1
    • if it doesn't work, its probably because the battery you replaced is also dead
    • Now turn it on and test if it works!
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
DID YOU ACTUALLY DO THE GUIDE??? CAN YOU LIKE GIVE ME A HUG PLEASE?????
Giahy Nguyễn
Membro da: 09/27/25
165 Reputazione
Una guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 3
Ultimi 30 giorni: 23
Tutti i Tempi: 83
