Introduzione
If you are having issues with the responsiveness or functionality of the key pad on your Casio Cassiopeia E-125, this guide will walk you through the process in 10-15 minutes.
Having a Flathead 3/32" or 2.5 mm Screwdriver, and a Phillips #00 Screwdriver will make this process more straight forward and reduce the possibility of complications.
In Step 9, proceed with caution: Potential for device damage. Do not pull apart the wires connecting the outer case.
Strumenti
Parti
Nessuna parte specificata.
Use the Phillips #00 screwdriver to remove the two screws near the top of the device.
Use the #00 Phillips screwdriver to remove the five screws on the back of the front case.
