Introduzione
This guide is to replace a damaged or broken piano key on your Casio CZ-1000 synthesizer. A broken piano key can cause the key to feel loose or be unresponsive.
Cosa ti serve
Use a Phillips #1 screwdriver to remove the eleven 7.5 mm screws securing the back plate.
Remove the four 7.5 mm screws using a Phillips #1 screwdriver.
Lift the rectangular circuit board away to expose the underside of the key bed.
Conclusione
2Commenti sulla guida
Disassembly went fine, but my cz1000 keys don't look the same
