Salta al contenuto principale
Casio CTK-501 LCD Screen Replacement
Cosa ti serve
  1. Casio CTK-501 LCD Screen Replacement, Bottom Panel: passo 1, immagine 1 di 2 Casio CTK-501 LCD Screen Replacement, Bottom Panel: passo 1, immagine 2 di 2
    • Flip the keyboard over so that the bottom is facing up.
    • Remove the twenty-seven 12 mm screws from the dark-grey panel using a Phillips #2 screwdriver.
  2. Casio CTK-501 LCD Screen Replacement: passo 2, immagine 1 di 1
    • Remove the bottom panel by lifting and pulling it towards yourself.
  3. Casio CTK-501 LCD Screen Replacement: passo 3, immagine 1 di 2 Casio CTK-501 LCD Screen Replacement: passo 3, immagine 2 di 2
    • Flip open the top half of the keyboard.
    • Set the keyboard onto the bottom half with the internal parts facing up.
    • Be careful not to let the bottom drop.
  4. Casio CTK-501 LCD Screen Replacement, LCD Screen: passo 4, immagine 1 di 1
    • Completely unscrew and remove all six of the screws on the central circuit board.
  5. Casio CTK-501 LCD Screen Replacement: passo 5, immagine 1 di 1
    • Lift the circuit board out of your way.
  6. Casio CTK-501 LCD Screen Replacement: passo 6, immagine 1 di 1
    • Remove tape from the LCD screen and remove the screen completely.
  7. Casio CTK-501 LCD Screen Replacement: passo 7, immagine 1 di 2 Casio CTK-501 LCD Screen Replacement: passo 7, immagine 2 di 2
    • Replace the LCD screen and tape it down to the top cover.
    O display do ctk 501 esta a venda? chama no whats 11 973620565
    Denis Novak - Replica
  8. Casio CTK-501 LCD Screen Replacement: passo 8, immagine 1 di 1
    • Place the circuit board back on top of the LCD screen.
    • Screw all of the screws completely in their original positions.
Conclusione
Altre 2 persone hanno completato questa guida.
Jimmy Winne
Membro da: 10/04/12
578 Reputazione
6 Guide realizzate
Cal Poly, Team 9-16, Amido Fall 2012 Membro di Cal Poly, Team 9-16, Amido Fall 2012
CPSU-AMIDO-F12S9G16
4 Membri
6 Guide realizzate
3 Commenti
Where did you get the replacement LCD screen? I'm looking for one for my CTK-573 keyboard mbuseck1@yahoo.com
mbuseck1 - Replica
Hi. Would this screen work for CTK 481?
José Saldaña - Replica
hi. I have the ctk 4300. i would like to know where i can get one.Binitintimo@gmail.com
timo binitin - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 20
Tutti i Tempi: 5,026
