Salta al contenuto principale
Casio CTK-3200 LCD Screen Replacement
Cosa ti serve
  1. Casio CTK-3200 LCD Screen Replacement, Center Front Panel: passo 1, immagine 1 di 2 Casio CTK-3200 LCD Screen Replacement, Center Front Panel: passo 1, immagine 2 di 2
    • Remove the seven 10 mm Phillips #1 screws on the underside of the keyboard that secure the center front panel.
  2. Casio CTK-3200 LCD Screen Replacement: passo 2, immagine 1 di 1
    • Flip the keyboard over and remove the central panel on the front and place it above the keyboard.
    • Make sure not to sever or strain any connections between the yellow-colored main board and the central panel.
    • If the panel is not easily removable, make sure all the screws are removed from the back.
  3. Casio CTK-3200 LCD Screen Replacement, Main Board: passo 3, immagine 1 di 1
    • Make sure you are not putting too much strain on the wires that connect the yellow board to the rest of the piano.
  4. Casio CTK-3200 LCD Screen Replacement: passo 4, immagine 1 di 2 Casio CTK-3200 LCD Screen Replacement: passo 4, immagine 2 di 2
    • Remove the three 12 mm Phillips #2 screws from the green PCB.
    • This step will require you to move some of the motherboard's wiring. Make sure not to separate any of the connection points.
  5. Casio CTK-3200 LCD Screen Replacement: passo 5, immagine 1 di 2 Casio CTK-3200 LCD Screen Replacement: passo 5, immagine 2 di 2
    • Remove all twenty-three of the 10 mm Phillips #1 screws from the yellow circuit board.
  6. Casio CTK-3200 LCD Screen Replacement: passo 6, immagine 1 di 1
    • The board is now able to be removed from the center front panel. Carefully remove the board, making certain not to break the board or any of the components attached to it.
    • Make sure the center front panel is facing down for this step, as the keys will come loose from the front of the panel.
  7. Casio CTK-3200 LCD Screen Replacement, LCD Screen: passo 7, immagine 1 di 2 Casio CTK-3200 LCD Screen Replacement, LCD Screen: passo 7, immagine 2 di 2
    • Carefully lift out the LCD screen.
    • If the screen has not been taken off before it might seem like it is glued to the board; this is normal.
  8. Casio CTK-3200 LCD Screen Replacement: passo 8, immagine 1 di 2 Casio CTK-3200 LCD Screen Replacement: passo 8, immagine 2 di 2
    • Place your new screen face down into the center panel. Lay the screen exactly as shown in the first image, then let it fall over and land face down into place.
    • Make sure the screen is right side up. This will ensure that all of the electrical components line up correctly when the main board is re-attached to the center panel.
Conclusione
Will Wright
Membro da: 10/23/24
369 Reputazione
2 Guide realizzate
Cuesta, Team 10-4, Krynen Fall 2024 Membro di Cuesta, Team 10-4, Krynen Fall 2024
CUESTA-KRYNEN-F24S10G4
4 Membri
6 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 18
Tutti i Tempi: 266
