Salta al contenuto principale
Casio A158WA-1 Watch Circuit Board Replacement
Cosa ti serve
  1. Casio A158WA-1 Watch Circuit Board Replacement, Circuit Board: passo 1, immagine 1 di 1
    • Remove the four screws from the back of the watch using a Phillips #00 screwdriver.
  2. Casio A158WA-1 Watch Circuit Board Replacement: passo 2, immagine 1 di 2 Casio A158WA-1 Watch Circuit Board Replacement: passo 2, immagine 2 di 2
    • Remove the back cover and the black rubber band with tweezers.
  3. Casio A158WA-1 Watch Circuit Board Replacement: passo 3, immagine 1 di 2 Casio A158WA-1 Watch Circuit Board Replacement: passo 3, immagine 2 di 2
    • Use a pair of tweezers to pull the small metal tab and remove the interior of the watch.
  4. Casio A158WA-1 Watch Circuit Board Replacement: passo 4, immagine 1 di 2 Casio A158WA-1 Watch Circuit Board Replacement: passo 4, immagine 2 di 2
    • Use a pair of tweezers to lift the metal clasps at each corner and remove the battery holder.
  5. Casio A158WA-1 Watch Circuit Board Replacement: passo 5, immagine 1 di 1
    • Separate the LCD from the circuit board.
  6. Casio A158WA-1 Watch Circuit Board Replacement: passo 6, immagine 1 di 1
    • Remember the position of the battery for reassembly.
    • Detach the battery from the circuit board.
  7. Casio A158WA-1 Watch Circuit Board Replacement: passo 7, immagine 1 di 1
    • Attach the battery to the new circuit board.
  8. Casio A158WA-1 Watch Circuit Board Replacement: passo 8, immagine 1 di 3 Casio A158WA-1 Watch Circuit Board Replacement: passo 8, immagine 2 di 3 Casio A158WA-1 Watch Circuit Board Replacement: passo 8, immagine 3 di 3
    • Place the new circuit board behind the LCD.
  9. Casio A158WA-1 Watch Circuit Board Replacement: passo 9, immagine 1 di 2 Casio A158WA-1 Watch Circuit Board Replacement: passo 9, immagine 2 di 2
    • Reattach the battery holder and push down on the clasps at each corner.
  10. Casio A158WA-1 Watch Circuit Board Replacement: passo 10, immagine 1 di 3 Casio A158WA-1 Watch Circuit Board Replacement: passo 10, immagine 2 di 3 Casio A158WA-1 Watch Circuit Board Replacement: passo 10, immagine 3 di 3
    • Place the interior of the watch inside of the shell.
    • Put the rubber band and the lid back in their original position.
Linea Traguardo
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 49
Tutti i Tempi: 1,117
